Thanks! I found the time today to pull the chassis. It looks like it's complete. ![]() Here's the HV coil. I like the primitive spot welded cover. Later versions were a single piece of stamped aluminum. ![]() As for the underside, it's somewhat different from later revisions. Here's a TS-4J for comparison. The two large metal HV caps are for the horizontal deflection plates. One thing I find odd is that this set has all plastic insulated wire. Every other TS-4 and TS-18 chassis I've worked on used cloth insulated wires ![]() ![]() All the non HV caps are Solar "sealdtite" branded as Motorola. They don't look to be very "sealed tite" anymore ![]()
