Old 10-14-2015, 10:12 AM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
Does anyone have Sams folder 6?
Working on a train wreck of a Westinghouse H-122 for a friend, and there are two resistors that are charred beyond recognition. This radio was really used to death. It's Sams 6-35.
First resistor is between pins 2 and 3 of the 25Z6
Second resistor is off of pin 8 of the 25L6
Much appreciated if anyone's got the info!
Old 10-14-2015, 10:43 AM
Findm-Keepm's Avatar
Followin' the Rules...
No, but Nostalgia Air has the Riders:
http://www.nostalgiaair.org/Resources/095/M0024095.htm
Looks like a 22 Ohm between 2/3 on the 25Z6, and a 91 ohm on the 25L6 cathode (pin 8).
Brian
USN RET 22YRS (Avionics/Cal)
Old 10-14-2015, 09:10 PM
Banned
I might have it, but not sure (the model of radio you're working on sounds familiar) I'll dig through my sams photofacts and see what I come up with.
Old 10-15-2015, 05:42 AM
Kamakiri's Avatar
Brian's got the needed info, thanks though! And thanks Brian, you came to my rescue once again!!!
Old 10-15-2015, 07:40 AM
Banned
Alright, thought I'd offer.
Old 10-15-2015, 08:37 AM
DavGoodlin's Avatar
Motorola Minion
That is one interesting circuit. The 25Z6 could have been used as a voltage doubler rectifier. Instead the cathodes and plates were parallel to increase current capacity.
I got one of these a long time ago and recently got a very similar H-247, both are missing the companion record players
-Dave G
