Old 03-23-2017, 11:00 AM
Still didn't figure this out, but there is 2 10meg resistors at the 6sl7 that I checked and also tried others and didn't work was the same no different but the one 10meg that is across pin 4 and 6 if I put a 1 meg across the 10meg I get a picture and vert hold the linearity is off on top and the hold is Alittle touchy. pin 6 is wired for ground and the one end of the .004 is also tacked to ground. It seems as if the tube is not conducting by why with a 1 meg it calls for 10 meg. If I try a 1 meg across the other 10meg it works very little bad picture and no response from vert hold or size. All this changes with the one resistor at 4 and 6 . I can't measure the voltage on the plates of the 6sl7 with a Dvom I won't get an accurate reading but measuring I do get a reading of 120 Vdc and 75 Vdc the SAMs shows a lot more so my meter won't tell but changing that resistor to a 1 meg I'm thinking lowering that resistor seems to allow the tube to conduct with possibly low voltage on the plates but the screen is super bright. The plates get voltage from the hv with the resistors which check ok. This is nuts already, I'm open to anything at this point
