Old 03-23-2017, 02:33 PM
The tube shouldn't make any difference, unless it is the cause of leakage... try it both ways. You could also check the tube itself for any leakage between pins, but since you have tried several different tubes without changing the symptoms, it is unlikely that you will find any leakage unless they all have the same fault.
