Old 01-21-2020, 03:51 PM
CrtsRtubular's Avatar
CrtsRtubular CrtsRtubular is offline
Sony Trinitron kv-1201 issue
This tv worked fine for a while and then one day it just stopped. Now it only shows this line. I replaced a bad capacitor but it still does this. Any Ideas?
Old 01-21-2020, 05:44 PM
You have lost horz deflection. It is almost always a bad cap in series
with horz winding of the yoke. Its a special non polarized electrolytic
& a wrong sub will quickly fail.
If you order a manual there are at least 2 versions of this set.
You need model, chassis & serial numbers to get the right one.
Old 01-22-2020, 06:27 PM
JohnCT's Avatar
JohnCT JohnCT is offline
What's more amazing is that the SCR didn't short and take the power supply with it.
John
Old 01-23-2020, 01:44 AM
MadMan's Avatar
MadMan MadMan is offline
The Resident Brony
Check all connections and solder joints. If that sounds like a pain, it is. But good chance it's simply a loose connection.
You can always try the caveman method.
Old 01-23-2020, 02:47 PM
Popester's Avatar
Popester Popester is offline
Could also be a broken wire or bad connection to the horizontal coils of the yoke. The KV-1201 didn't have the SG613's the blew. Those came along about '74 '75 models.
My wish list:
Sony KV-7010U
Sony KV-1220U
