Old 08-07-2023, 05:21 PM
On V19 the difference in voltages on pins 6 & 3 is really pretty big considering there
is a low ohm coil between those two pins...... Timmy are your readings correct?
Is that Primary winding of L29 Pins 1 & 3 ok? I don't think there should be
such a large difference in Voltage unless possibly that primary is open...
Just test it don't replace it, be sure solder connections look good
no corrosion, cold joints..... Is it around 9 ohms...?
