Old 08-08-2023, 07:21 PM
Here’s the voltages
V21. I probed the wrong side of v22 it does have voltage. I missed B section of v19 I’ll post the voltages
1 180.6
9 -44
6 352.3
3 123.7
7 180.2
2 123.3
Timmy, on V21 do pin 2 & 3 really have the same voltage on both pins....?
Can you investigate this ? Can you check resistance compare to Sams
on these pins? Possible short in the socket, or internal to the tube?
I'm not sure about R166, R167, & C116... Not sure what to do
with the flyback pulse at this point. I would be happier solving
the odd voltage stuff first & being somewhat sure those items
look like they are working.... If you guys want to pursue
the flyback pulse it's ok, I just don't know how your
going to test for it. But we could test for the tube
voltages with the tools Timmy has.....
Either thing could be just a tail
chase anyway....
I’ll check those pin voltages again does seem odd.
