Old 03-18-2024, 10:34 AM
pac.attack76's Avatar
Stuck in the past
Went down to the dungeon today. Pulled Sams 1949-1
Breaker on sec of transformer & kills the 143 source. PS is
copy of Zenith with the oil cap
S cap is C702 .00155 mfd 1.5 KV P# EP18X137 Its behind
the HOT & a few inches away.
First checks are
Reset breaker.
Check for @143 VDC at case of HOT
" " " 24 VDC at PGRL5 of the little rectifier ( red wire ) board.
For meter GRD use the CRT grounds.
Burning can be a lot of things. You have to go step by step to narrow things down. Usually the FBT or vert module on these & do it without spending $$$
Zeno
Ok thanks 👍, I'll get in there and see what I come up with.
Genesis does what Nintendon't
Old 03-18-2024, 10:37 AM
Stuck in the past
First checks are
Reset breaker.
Zeno
Ok thanks 👍, I'll get in there and see what I come up with. Also, when I push the breaker, should it stay all the way in, or does it come back a little bit?
Old 03-20-2024, 11:58 PM
Most sets it comes back a bit. It it was tripped you'll feel/hear a click when you reset it, if it wasn't tripped you'll feel some spring pressure and maybe scraping.
