Old 11-09-2003, 05:38 PM
Need Emerson schematic
The Sam's I have (46-25) for my Emerson 571 is for an earlier/later chassis and doesn't show the ballast tube.
Does anyone have a different schematic for this set that does show the ballast?
I could use a scan of the power supply section.
Eric
Old 11-09-2003, 06:12 PM
Steve K Steve K is offline
Eric:
Is this the one you need?
Steve
Old 11-09-2003, 06:16 PM
Now it would probably help to have the values!
R47 and R48; 10 ohm 3 watt wirewound
R49 and R50; 75 ohm 5 watt wirewound
R103; 75 ohm 3 watt wirewound
Old 11-09-2003, 07:53 PM
Steve, that's it!
Thanks a million!
Eric
Old 11-11-2003, 02:25 PM
wiseguy wiseguy is offline
hi eric,i found that ballast,it is the correct one you need,and is brand new in the box,nice and black and shinny..!
i checked the pins to make sure..
sorry it took me a few days to dig and find it,i will send it to you..
terry
Old 11-11-2003, 03:32 PM
Thank you Terry, that will make the job so much easier if I don't have to hang a bunch of resistors all over the place
