Old 04-20-2008, 08:04 PM
Oldstuff78's Avatar
Oldstuff78 Oldstuff78 is offline
What Year Is This Set ?
Does anyone here know what year this old RCA set is ? I'm guessing early 1950's. it screams "I Love Lucy"
http://cgi.ebay.com/Vintage-RCA-Vict...QQcmdZViewItem
Old 04-20-2008, 08:52 PM
David Roper's Avatar
console lover
1954 or '55.
Long after the episode in which the Ricardos buy the Mertzes a TV set and end up in court. That was IIRC, a 1952 Westinghouse.
tvontheporch.com
Old 04-20-2008, 08:53 PM
hposter hposter is offline
hposter
1953 Rca Tv
It's a 1953 model, the 21-D-317...the "Merritt" (yep, 2 R's and 2 T's)!
21AP4 CRT, 21" Deluxe TVs (so says RCA's Service Manual--1953-T4).
Old 04-20-2008, 09:02 PM
console lover
I stand corrected. It's not a color set though.
That's a reference to it being posted in the color forum and probably not to anything else....
tvontheporch.com
Old 04-20-2008, 09:20 PM
Oldstuff78's Avatar
Talking
I knew I would get Busted for it being in the color forum. ....but I like to be a rebel.
It is a nice set though.
Old 04-21-2008, 01:13 AM
I plugged it in to test, (!) and there was a slight box of snow showing, but it stayed at about one-fourth of the whole screen, and I could get no sound
That likely means that the unobtanium parts are likely good (CRT, flyback, yoke, vertical out, power transformer) and is thus probably restorable.
Old 04-21-2008, 01:28 AM
Looks like it has the CT-100 type tuner and knob.
Old 04-21-2008, 11:38 AM
kx250rider's Avatar
REAL TVs have TUBES!
You're 100% correct! It has the same tuner (KRK-12), and the same knobs. The CT-100 version is a KRK-12C, so it may have a more selective design, or something. Only physical difference is in the center dial, which has that sporty arrow-looking thing on the B&W set, and is a plain brass disk on the CT-100. The pencil box door is also identical to the CT-100, but of course has different control holes drilled. I've used one of those on a CT-100 by drilling more holes
Charles
