Old 05-29-2008, 02:58 PM
funken's Avatar
funken funken is offline
European to U.S conversion
Hey guys!
Just purchased a telefunken set.
The cord was spliced with an U.S. two-pronged extension cord wire.
I believe this set had the European 3-prong plug.
When I test the two prongs with my meter I get no reading.
When I test the original wire from the set I get a reading.
How should this set be wired for U.S. use.
Thanks!
Funken
Old 05-29-2008, 07:22 PM
electroking's Avatar
a- v- karma member
Isn't the European 3-prong plug the same scheme as the U.S. one, that
is two power wires and a protective ground? You need to make sure
that your radio has a multi-voltage power transformer, and that it
is set for 110 or 120 volts. If possible, post some pictures of the rear
of the radio. Good luck, wait for some more answers if you are not sure.
Old 05-30-2008, 07:33 AM
myrgatroyd myrgatroyd is offline
Ah, it´s you again. Did your radio come in one piece? Grin.
A picture could be helpful.
Your radio has a protective ground? Must have, for you are speaking of three wires in a chord. This is unusual for old german radios. All of mine had just a two-wire chord, exception is an amplifier with an iron housing.
Did you check the two-wire chord itself? Perhaps it is broken?
The european setup for protective ground cords is: Blue=hot
brown=hot
yellow/green=protective ground.
Hope this helped.
Alex
