Old 06-26-2008, 01:34 PM
auplater's Avatar
auplater auplater is offline
"Mine goes to eleven!!"
Restoring 37-116 Deluxe
I recently came into possesion of this '37 Philco for not alot of $$, so I'm now deep into restore mode.
First, the b4 and after cabinet pics...
B4
After
After with cleaned and reinstalled original grillcloth
Onto the chasis... currently in-process (loonng process)
B4...
Starting on tube shields... re-plating them first
I'm currently tracking down replacement caps and cloth cov'd wiring to "dig in" on the chasis restore.
Just what I need, another project...
Speker is in prisitine condition...
l8tr
John L.
Remember the Golden Rule: Them with the gold make the rules
Old 06-27-2008, 05:15 PM
Reece's Avatar
Reece Reece is offline
Very nice job on the cabinet. Be interested to see the shots along the way as the "guts" progress. Can you please explain how you are going about replating the tube shields? Having them done outside? Expensive?
Thanks,
Reece
Reece
Old 06-28-2008, 10:29 AM
auplater's Avatar
thanx...
I do the plating myself... it's a multi step process of de-rusting (pickling) copper plating then bright nickel...
Dunno what it would cost from a commercial shop... maybe $10 - $15 each if supplied in bulk... probably with a minimum order of $100 maybe for the work?
I've started stripping the large caps and cleaning the chasis up...1st 2 cans have been d/c'd and polished.. waiting for caps to replace...
Here I've started to remove chasis rust,... I may spot plate the areas with zinc to prevent future rust.. or I may mask the non-chasis components and spray with krylon nickel... dunno yet.
Here I've made new rubber bushings for the chasis mounts to the cabinet, from a sandpaper eraser/cleaner... they're about the same durometer and work great
John L.
Old 06-28-2008, 10:47 AM
myrgatroyd myrgatroyd is offline
Really good work! Will be a fine console. It is to sad, that you can´t see the chassis anymore when reinstalled. grin.
Yours
Alex
Old 06-28-2008, 05:58 PM
Tony V's Avatar
Tony V Tony V is offline
Nice job on the Philco John! I cant wait to see the finish product.
-Tony
