Old 06-26-2004, 10:55 PM
Picked up a 1948 Emerson.
Cory, I believe you have one just like this?
Picked it up near San Diego today.
It's in pretty good condition and complete except for the incorrect channel selector knob (anyone? anyone. )
the CRT had a big short on the G1 (what exactly is that anyway?)
I zapped it with the "remove shorts" function about a half dozen times and it went away for the time being. Didn't have any emissions either till I cooked it at 8.5 volts for a while, now it checks really good, we'll see how long that lasts.
The set doesn't work, just hums out the speaker so it needs caps.
Eric
Old 06-27-2004, 07:16 AM
ChuckA's Avatar
ChuckA ChuckA is offline
Eric,
Email me your address and I'll send you the knob.
G1 = Grid #1, usually where video signal is connected to CRT.
Chuck
www.myvintagetv.com
Old 06-27-2004, 10:37 AM
mbates14 mbates14 is offline
ouch.
That had to do some damage to the video output circuits.
Old 06-27-2004, 11:08 PM
Cory's Avatar
Cory Cory is offline
Cory Heisterkamp
Hey Eric,
Yep, that Emerson is just like mine. In fact, I changed out the 'lytics tonight. It looks like a real easy set to work on too. I'll keep my fingers crossed for your crt.
Old 06-27-2004, 11:42 PM
Hi Cory.
I looked up the thread on yours, man your set is just like new!
This one is very clean but not like that.
Old 06-27-2004, 11:45 PM
Hmm, so unlike the H-K short I guess an isolation transformer won't help this one?
Chuck
Old 07-01-2004, 12:25 AM
Tinkering
Played around with this set a little tonight.
The CRT still checks really good, the short popped up just for a moment and now is gone.
Pulled the HV cage off and the 6BG6 had a white getter and in fact was broken around the bottom near the base. Installed a new one and I have some HV at the top of the 1B3 but nothing coming out the bottom.
I suspect the B+ is low from bad capacitors and it's just not generating enough HV to fire the heater in the 1B3.
Something else I noticed, while I had the CRT connected to the tester and in the "Emissions" position, there was a purple glow inside the neck under the Ion trap. This was the "Good" "surface of the glass glow" and not the "Gassy inside the elements type of glow"
It didn't do this when the set was turned on so I would guess the tube was not being driven by the video circuits?
Eric
Old 07-01-2004, 12:52 AM
tvman39
Guest
Posts: n/a
I had a picture tube that had a glow inside the elements it this the first hour or so it was in service.The gas in the tube must have been"burned off"
Old 07-06-2004, 10:03 PM
or the getter absorbed it.
Thats what the getters are for. Its serving its purpose.
Old 07-19-2004, 09:03 PM
A big thank you to Chuck A
Chuck found and sent me the tuner and fine tuner knobs I needed to make this set complete!
Old 07-19-2004, 10:10 PM
Great looking little set. Can't wait to see pics when you get it working ! -Sandy G.
