Old 08-29-2004, 05:46 PM
Charlie's Avatar
Charlie Charlie is offline
On Land
Philco color set... less than a day left
In Alabama. Claims the set works, although no photo of it on. Maybe a CTC10 or 11 clone?
http://cgi.aol.ebay.com/ws/eBayISAPI...744044967&rd=1
Charlie Trahan
Old 08-30-2004, 10:54 PM
reeferman's Avatar
Referencing "Color tv servicing made easy" (Sams 1963), Philco didn't use the RCA CTC-10 chassis. Philco's 1280,U chassis is similar to the CTC-11 chassis
Old 08-31-2004, 08:21 AM
generally, I think 4 knobs at the bottom means 11, 3 knobs means 12. But I'm not sure about the CTC-10's layout.
Old 08-31-2004, 08:57 AM
Chad Hauris's Avatar
Which is the last vertical style chassis that stands on edge in the right hand side of the cabinet? CTC-10 or 11?
Old 08-31-2004, 09:36 AM
11 was on it's end; I've never seen a 12 in person.
Old 08-31-2004, 10:40 AM
O.K., I guess the 12 was the one that was like the 15 but used an octal horiz. output tube (6DQ5?)
It seems to me like the revisions of this chassis are:
CTC-12: Octal H.O. tube, selenium focus rectifier, 3a3 and 6Bk4 mounted horizontally above flyback in cage.
CTC-15: Similar to CTC-12 except uses 6JE6 9-pin H.O. tube.
CTC-16: Uses the flyback where the 3A3 plugs into it. Uses a tube type focus rectifier.
CTC-17: Same as CTC-16 but uses rectangular crt, adding pincushion components and degausser.
CTC-25: Similar to CTC-17 but uses transistorized audio section.
CTC-28: Returns to tube type audio section.
CTC-35: All models equipped for remote control.
All of these seem to be essentially similar...there were also some other changes along the way, such as using a bridge rectifier rather than a voltage doubler and substituting solid state diodes for the 6JU8.
Old 08-31-2004, 04:32 PM
Steve D.'s Avatar
Steve D. Steve D. is offline
CTC-Knobs
The RCA Field Service Guide shows the CTC-10 & 11 had 4 knobs on the bottom. The CTC-12-15 had 3 knobs.
Old 09-06-2004, 02:34 AM
Re: CTC-Knobs
I had a 1964 Silvertone roundie about 30 years ago. These sets were made by Warwick Electronics for Sears, but the chassis and front-panel layout screamed RCA CTC12. Three knobs on the panel (brightness, color, tint) and a trap door behind which were the contrast, v/h hold and tone controls. Classic RCA CTC12 chassis layout, but I'm not sure anymore about the horizontal output tube.
