Old 09-20-2010, 08:49 PM
ctc17 ctc17 is offline
2 rca projection sets. CL5 and 8PCS41
The blond one (8pcs41) has channel 1, 5TP4 crt. The dark one (clubman cl5) is missing several parts. Dont really know what to do with these. I bought them as part of a package deal.
Im still trying to figure out how these things work with the crt pointing down. Must have a mirror in the bottom.
Any thoughts would be appreciated
Old 09-20-2010, 09:05 PM
AUdubon5425's Avatar
I found a little info on the 8PCS41 on this website: http://www.jitterbuzz.com/indtv.html. Says 33 tubes plus 7 rectifiers! I say put it in a cold room.
From an old thread http://www.videokarma.org/showthread.php?t=51488 it seems like the Clubman was a $1400 set in 1948, and there were five versions. There was also a brief mention of it in Billboard 6/26/48 in a story about Boston hotels buying TVs - it said the Sheraton chain was using the Clubman, with a 15x20 screen large enough to be viewed by over 200 people!
AUdubon5425 Youtube Channel
Old 09-20-2010, 09:29 PM
TubeType's Avatar
TubeType TubeType is offline
TubeType Sets
Early RCA Projectors
If you look down the round hole on the Clubman's projector, you will see a large concave mirror at the bottom of the assembly. There is a clear plastic, currently covered with dust, lens surrounding the hole. This is the corrector lens. The image from the missing CRT is reflected by the concave mirror, through the corrector lens, to a flat mirror located behind the lenticular screen, and is finally displayed onto the screen.
Caretaker: RCA CT-100
Terry's Tube-Type Sets
Old 09-20-2010, 11:14 PM
I've always wondered how this works what with all those wires and hardware in the path of the light from the mirror,
Old 09-21-2010, 12:17 AM
ChuckA's Avatar
ChuckA ChuckA is offline
Here's a link to a Philco paper on the fundamentals of projection TV systems.
http://www.myvintagetv.com/Apple%20P...n%20Lesson.pdf
The 1948 8PCS41 and the 1949 model 9PC41 are probably the most common projection sets found, the Clubman models are rarely found.
Chuck
www.myvintagetv.com
