Old 01-27-2011, 09:13 PM
miniman82's Avatar
First Light: 1952-2011
What do we think about this? (Predicta content)
not affiliated
I actually like it, but the price is a bit steep. Looks like it was well done, I like the idea of a modern color TV in Predicta form.
http://sacramento.craigslist.org/ele/2180476008.html
Evolution...
Old 01-27-2011, 09:14 PM
miniman82's Avatar
Didn't know there were reproductions of that set either: http://sandiego.craigslist.org/nsd/ele/2183973555.html
Evolution...
Old 01-27-2011, 09:55 PM
Telstar's still around apparently.
http://www.predicta.com/index.shtml
I'm not sure who made that first set with the more rectangular screen, I recall someone other than Telstar doing it though.
$700 is cheap compared to the $2500 they cost (or did cost back when) I think they had
RCA XL100 parts inside.
Old 01-28-2011, 12:30 AM
GeorgeJetson's Avatar
GeorgeJetson GeorgeJetson is offline
You're right,
The tv in the first post was made by CB electronics using Rca tv components,they were around before Telstar started doing predicta reproductions too.
I still have an old CB electronics brochure for that set somewhere and they were quite expensive.
No wonder this circuit failed,it says "made in Japan"!
Old 01-28-2011, 10:51 AM
kx250rider's Avatar
REAL TVs have TUBES!
There was also a (private party/garage factory) who was putting new Korean boards from 12" cheapie B&W sets from the 2000s, into Predictas, and driving the original CRT. I'd be curious how they made that work with the yoke, as the last 12" B&W sets had skinny necks, and no way would the yoke fit the 17DRP4. And I don't think you could make a tube-type yoke work with a solid state board. I saw at least a half dozen of them, so it wasn't a one-off idea. They were decent jobs, with the tuner adapted to the Predicta knobs, and also the coaxial ON-VOL, and Contrast pots were retrofitted. Nice job actually.
Charles
Old 01-28-2011, 11:06 AM
That's interesting!
Still I bet those retrofits would cost more than simply sending your predicta chassis out to David Weddington to have it rebuilt.
Old 01-28-2011, 11:09 AM
too bad when they made the new versions the plastic mask wasn't the same size and shape because you could replace a bad/cracked one with it
mike
Old 01-28-2011, 04:40 PM
ctc17 ctc17 is offline
This is just weird. The green boarder looks better than the black.
The yokes should be fairly easy to adapt to solid state as they are low impedance. The fly or v out transformer adapts the low yoke impedance to the tube.
