Old 08-02-2012, 03:46 PM
mrflex65's Avatar
mrflex65 mrflex65 is offline
Hitachi CT-1909
It's been awhile folks,found this Hitachi CT-1909 19" set from '80. It's filthy,but it should clean up pretty nice! Can't say so much for the remote though. Anybody here familiar with this set? Looks to be well built..
"IPC 610 Class E & J STD-001 Certified"
Old 08-02-2012, 04:14 PM
mrflex65's Avatar
A few more pics.....
Old 08-02-2012, 06:22 PM
I like it! Hitachi built a lot of good sets back in the day.
Old 08-02-2012, 08:56 PM
Looks like there used to be a chrome keypad insert on the remote.
Old 08-03-2012, 05:42 AM
mrflex65's Avatar
I really like this set! I'm going to hang on to this one.
Old 08-03-2012, 06:01 AM
mrflex65's Avatar
Yes, the keypad insert is missing along with the battery cover and corroded batteries to boot! It's a goner... From what i understand, they still have some replacement remotes for this set....
Old 08-03-2012, 07:42 AM
DavGoodlin's Avatar
Motorola Minion
I had to repair one of these for a friend when I was only good on Sony (not boasting here, I worked for 2 Sony dealers so I HAD to do them right)
The Hitachi had "Jail bars" on the left side of the picture. Still under the impression a 3 year old TV couldn't possibly have a bad capacitor, I wasted lots of time before a bad 47 mf(?) 250 volt cap was found on the CRT PCB? on the CRT's G2 supply line. This allowed horizontal-rate ripple to modulate the G2 voltage and cause the odd symptom.
Once done, it looked great.
Old 08-03-2012, 10:30 AM
mrflex65's Avatar
Ok, got a chance to clean it up and pop off the back cover. Not too bad inside! just a little compressed air and it's done.All i have to do is some detailing on the front and that should do it.
Dave,i didn't see that cap on the crt board.I guess maybe on the main pcb?
Old 08-03-2012, 10:34 AM
mrflex65's Avatar
A few more.
Old 12-06-2014, 09:05 PM
Dreamsbeard's Avatar
Dreamsbeard Dreamsbeard is offline
Well this looks familiar!
Old 12-07-2014, 08:22 AM
The cap is a good one to learn. Its common to almost
all SS sets & has a high fail rate.
To find it: on CRT board the 3 color output collectors go through
apx a 15K or 18K 1 or 2 W resistors. Where they join is the 200
volt source. Follow the wire from that to the main PCB. You
will find it there. Usually a 4.7 mfd sometimes a 10 mfd.
Change to a 450 volt. Usually near the flyback.
Symptoms are a mix of jail bars, smearing, dark on
left to bright on right, bright blank raster, retrace, shading Some
sets will go into overcurrent shutdown also.
