Old 12-04-2013, 10:38 PM
47'Plymouth 47'Plymouth is offline
Smile Scored a 1947'Tele-Tone TV-208,SuitCase portable
Hey Guys,
a barn find,1947'Tele-Tone Tv,model TV-208 SUITCASE portable
In complete but very rough condition here in the upstate South Carolina
It's has a 7JP4 CRT,but don't have an adapter for my Sencore CR-161
Tester to see if it still has life left in it
I've heard you use test clip on these odd ball tube
Also need a Schematic for it too and yes the pins are very loose
On the CRTs base it I'm scared to move the base!,needs to be re soldered
Does any else here own one
It's a series string set NO POWER TRANNY TO WORRY ABOUT!
Old 12-04-2013, 10:51 PM
David Roper's Avatar
console lover
Not to buzzkill, but that's a 1949 TV. Incidentally,
tvontheporch.com
Old 12-04-2013, 11:11 PM
Nice find. I have a TV220 which is pretty close. You can check the 7JP4 filament continuity with an ohmmeter or apply 6.3 vac and look for a glow. Filament is pins 1 & 14.
I think I'd prefer a power tranny - less chance of the tube filaments burning out.
Old 12-04-2013, 11:18 PM
Also some posting tips(so folks can read and actually understand what you type). First this is a computer not a typewriter DO NOT hit enter when the line you are typing approaches the right edge of the text box, and instead continue to type. The computer will drop you to the next line on it's own when you reach the edge, and it will keep you from having
a sentence that should
fit on one line get divided
into several like this here
sentence I wrote to illustrate
how annoying it is to read.
Also a sentence begins with a capital AND ends with a period(exclamation or question marks are also acceptable if not over used), and words in the middle of a sentence should not be capitalized unless they are a proper noun, acronym, or you put a word in CAPITAL letters to emphasize it's importance.
I want to help you with your set, but there are so many ways to interpret what you typed that any advice I could give would most likely be based upon a misinterpretation of what you wrote, and thus be of no value to you.
Old 12-05-2013, 12:14 AM
You can download the Sams service manual for the Tele-Tone TV-208 from the ETF schematic archive:
http://www.earlytelevision.org/tv_sc...s_postwar.html
Resoldering CRT base pins usually isn't difficult. Heat the pin and wick a little extra solder into the end if needed. Everyone seems to have a different favorite glue for re-securing tube bases. Since so many of them seem to work, perhaps the type isn't critical. I prefer something like sensor-safe RTV, which has a little flexibility.
Phil's Old Radios
Old 12-05-2013, 12:48 PM
ggregg's Avatar
ggregg ggregg is offline
You know, Jody is excited about what he found and what does he get? Raked over the coals over spelling and grammatical errors. It doesn't seem to bother anybody else so,
if you don't like the way it's typed
and the working and spelling is not
up to your lofty standards:
Don't read it.
Old 12-05-2013, 01:05 PM
azbigsam azbigsam is offline
I second what ggregg said. The reason we post on here is because we all have been bit by this rare bug and usually aren't surrounded by people that understand our passion. (certainly my wife isn't going to share my excitement when I bring home a new "treasure"). I enjoy posting finds and seeing that it excites other people too as well as all the information that you will gain about it from the kind people on this forum. Perhaps if we have advice to give to people we can do it in a kinder way.
Good luck with your new set 47'Plymouth! Look forward to hearing more about it.
Old 12-05-2013, 02:17 PM
Steve McVoy's Avatar
Actually the TV-208 was made in 1949.
Old 12-05-2013, 03:44 PM
holmesuser01's Avatar
I wonder what they watched on this set? We didn't have TV until WBTV in Charlotte came on in 1949 in our area.
Dunno about 4 or 7, but 13 in Asheville hit the air in 1954.
Oh yes, congratulations on your find!!
Edit: Just saw Steve's comment about the age of this set.
Bruce
Old 12-05-2013, 03:50 PM
Good for you '47!
Well I think you should Skip the dam tube tester,
Plug the dam thing in, turn it on, and see what it does,
and if it needs a new transmission I bet someone knows where to git one.....
Good Luck ! ! !
Old 12-05-2013, 04:28 PM
That set isn't likely to do anything until you replace the electrolytic capacitors (at least), but at least you don't have to worry about frying a power transformer.
I suspect the electronic design is fairly conventional for a 7-inch TV of that vintage. In this section of my website you'll find restoration articles for other 7-inch TVs (Admiral, Hallicrafters, Motorola, National):
http://antiqueradio.org/televisions.htm
None of those is identical to yours, but if you skim a couple of the articles you'll get an idea what it usually takes to get one of those running.
Phil's Old Radios
Old 12-05-2013, 05:17 PM
tvdude1 tvdude1 is offline
Im with you boys. This is suppost to be a fun hobby, and to help others. Not to bust BALLS over minor Shit.
Old 12-05-2013, 05:45 PM
Ya Done GREAT !
Old 12-06-2013, 04:13 PM
I did not "bust BALLS" I'm trying to help him make his posts easier to understand so he does not have to waste his time clarifying his questions or statements. I want to help him and a grammar lesson seemed like the biggest help I could readily give.
Ggreg is full of Sh!t. He screwed me over some time ago and ever since I had the GALL to call him out on it he has taken every possible chance to slander and pick fights with me (even now long after I have tried to put it behind me and not do the same SH!T to him). I think he should do exactly what he once advised me to do, namely "Get Stuffed".
I've stopped being as petty to you Ggreg as you STILL are to me; It is time you started acting like an adult and quit trying to insult and pick fights with me, that is if you are actually mature enough to do so.
Old 12-06-2013, 05:40 PM
console lover
Tom, you not only posted like a dick, you happen to live in a great big huge glass house on the very issue you were trying to "help" with--so dickishly. Own it.
tvontheporch.com
