Old 12-29-2013, 06:44 PM
Bobby Dip Bobby Dip is offline
Any info on this tuner?
The tuner on my Delco experimental TV does not have a name brand. But it has these markings:
TV-6519
470771
D443C
It would be nice if I could find a schematic for it, or even what terminals A,B,C,D are. Maybe these numbers could at least date the set. The tuner is rather large and has no channel 1.
Bob D.
Old 12-29-2013, 08:15 PM
TV-6519
470771
D443C
Bob D.
It's a Standard Coil, similar to the Admiral tuners.
Old 12-29-2013, 08:32 PM
You beat me to it Does it use a 6AG5 and 6J6 ?
Old 12-29-2013, 08:40 PM
Warning: do not do any work on that tuner outside of cleaning contacts and changing tubes. Lead dress in TV tuners is extremely critical and should only be messed with as a last LAST resort.
Old 12-29-2013, 08:46 PM
It might be a 6U8 and a 6BQ7, but don't quote me on it.
Old 12-30-2013, 06:30 AM
Mal Fuller Mal Fuller is offline
I believe the manufacturer's name was Standard Kollsman.
Old 12-30-2013, 09:37 AM
The tuner has a 6U8 and a 6BZ7.
Bob D.
Old 12-30-2013, 10:15 AM
The firm changed their name sometime in 60's Before it was called Standard Coil Products Co. Their EIA code is 305.
Old 12-30-2013, 10:22 AM
Bob D.
There's a strong possibility, that the set has a 41MHZ if strip.
The 6BQ7A is a direct replacement for the 6BZ7. Standard used both. If the tubes are original, they should be stamped "Standard TV".
Old 01-03-2014, 09:05 AM
The tuner seems to be in good shape, so I won't touch it. I do need knobs for it, where can I get knobs? It has concentric shafts, 1/4 and 3/8 inch, with flats. (It doesn't matter what the knobs look like.)
Oh yes, I also need knobs for the volume control. This control has concentric shafts, 1/8 and 1/4 inch. These shafts are also keyed with flats.
Bob D.
Old 01-03-2014, 09:21 AM
Bob D.
Anyone, that has a large knob stash, should have the knobs that you need.
The volume control is probably a contrast control, as well. The smaller shaft is really 3/16". Those knobs are common too.
Old 01-03-2014, 05:22 PM
Tubejunke's Avatar
I've seen a few of those through the years and love the design from a cleaning standpoint.
Old 01-03-2014, 05:36 PM
Kevin Kuehn's Avatar
Workin' Late Again
Are there any size restrictions on the diameter of the knobs? I have a set of four knobs off a Silvertone console that you are welcome to for postage. The outer knobs are 3".
