Old 08-03-2014, 06:02 PM
Doug_90 Doug_90 is offline
Back Cover For My RCA Victor
I refinished an RCA Victor VR-60 that my mother bought in 1941...
Gregb, a member here, did the electrical for me.
Anyway, the back cover is long gone. I have vague recollections of it but the memory is foggy. I realize I'm going to have to make my own, but can anybody tell me what the material used for that model and vintage of RCA was?
Old 08-03-2014, 09:23 PM
DavGoodlin's Avatar
Motorola Minion
I think by that time, a product commonly known as "masonite" was used. It is a sheet of medium density fiberboard with holes punched in it. Some manufacturers claimed better sound by using a back cover. I have a 1938 RCA U128 that has screw holes for back cover as well.
By the way, that is a nice RCA Victor. What features on record changer is in it?
At that pre-war time Philco was advertising the beam of light pickup instead of the replaceable needle..
-Dave G
Old 08-03-2014, 10:28 PM
Thanks, DavGoodlin!
Unfortunately the original record player (an automatic 78) disappeared about the same time as the back cover, sometime in the early 1960's, and was replaced by a Moose (that's the brand name) turntable. I've left it out and use the RCA jack as an input for an iPod. I just remember it was an automatic changer and made a cool frrrrppp sound when I ran my finger across the needle.
Used to irk my dear old Mom...
Old 08-03-2014, 10:47 PM
NoPegs's Avatar
NoPegs NoPegs is offline
The glass is -3dB.
'Yo Mama...
Made a very good purchase back in 1941.
Masonite is still available, you're looking for something that on one side looks like a traditional clipboard board, and on the other it will have an unifinished surface with texture like a window-screen. You can find it with either both sides smooth or both sides unfinished, but normally its just one side. Also commonly used as the material of drawer-bottoms for cheaper furniture, but it looks like you need at LEAST 1/2 of a 4x8 sheet for that very attractive piece of cabinetry, possibly more so I don't think you can harvest yours from a dresser...
Old 08-03-2014, 11:46 PM
Thx, NoPegs! Yes, my Mama was proud of her radio.
It has special significance for me. Two of the most vivid memories of it are hearing The Beatles for the first time, and coming home and seeing my mother sitting in front of it weeping over the news of the death of President Kennedy.
The SW exposed me to foreign radio stations and made me want to visit those places.
I was thinking of standard hardboard at Home Depot.
Hardboard
It's close to what I think I remember... So I guess I'm on the right track.
Old 08-04-2014, 09:20 AM
Does the radio have a swing out type loop antenna in the bottom of the cabinet? The black cardboard type materal, that covers the loop assembly is the same type, that the back cover was made from.
They still make the stuff. The back covers from the Sauder assemble-it-yourself furniture, still uses it.
Old 08-04-2014, 09:40 AM
Thanks, DavGoodlin!
Are you sure the name isn't "Morse", which is probably a re-badged BSR.
Old 08-04-2014, 02:55 PM
Yes, I know what you mean. There are little tabs still attached to the back of the radio and they look to be more suited to affixing a thinner cardboard material to the back than a heavier hardboard.
I'll need to look into this a bit more.
No, it's Moose. It even has a 3/4 profile drawing of a moose's head and shoulders.
Thanks, DJ
Old 08-06-2014, 07:36 PM
Reece's Avatar
Reece Reece is offline
You can get Masonite in 1/8" and 1/16" thickness. The thinner stuff would be fine for a back. The trouble is getting a pattern of slots and holes to look good and even. Takes some careful layout and cutting. The easiest for tube cooling is a slot across the top and one across the bottom of the chassis area, allowing for air in, air out. Here's an example of one I did in the thin Masonite for a table set.
Reece
Old 08-07-2014, 09:00 AM
NoPegs's Avatar
The glass is -3dB.
http://i177.photobucket.com/albums/w...oneback004.jpg
What's the trick for making the edges on the cutouts look so damned nice? Just a very high speed router bit to give that smooth factory-like edge? In my head I had just sort of always thought that the originals were made on a punch/press/die-cutter type thing, and that trying to replicate that in the home workshop was difficult. Obviously if you know a guy who has access to a water-jet table it comes out better than attempting it with a jigsaw or cope or even a dremel, but the idea of a router had not occurred to me.
Old 08-07-2014, 05:29 PM
Well, for the interim I got some 1/8 foam core board. I think it does make the radio sound better. While the radio was playing I touched the back and could feel it vibrating like a speaker cone.
I still have to cut out a couple of vents for the receiver compartment. That's only about 12X12 inches and the rest is just open cabinet space, so thankfully i won't have to do too many cuts to get adequate airflow.
Old 08-07-2014, 07:51 PM
Reece's Avatar
Wish I had a router but I made my cuts using a hole saw in a drill press to make the two ends of the slot, and then clamping a guide to the back and cutting between the holes with a saber saw.
Reece
Old 10-06-2014, 12:08 PM
willy3486 willy3486 is offline
Years ago I rebuilt a guitar amp for this fellow in a band. After I got it going he could still hear a faint vibration. I knew I had the amp rebuilt fine so I had him to play it for me. We found out the case and back cover that was screwd in was vibrating and you could hear it. To solve that issue I used some weatherstripping foam between the cabinet and back cover. So if the vibration gets annoying for you then you might could lay a line of the peel and stick roll of foam weatherstripping to get it to stop.
