Old 12-04-2014, 06:09 PM
Winky Dink's Avatar
Winky Dink Winky Dink is offline
AK 30 Audio Xformers & Missing Resistor
I'm doing the cosmetics on the components of an Atwater Kent 30, but there's one data item which I'd like advice on before I proceed. Here's the data for the audio transformers:
The resistance of one of the coils varies a little more (I believe the technical term is "out of whack") from the specs than I've come to expect.
Should the primary of the 2nd audio should be a concern, or should I just proceed as it stands and see what happens?
There's also a resistor on the schematic which I haven't found yet. If I can't figure it out when I rewire the set, then I'll ask about that.
Many thanks.
Winky Dink
Damn the patina,
Full speed ahead!
Old 12-04-2014, 06:28 PM
My AK40 was further outa whack value wise, and still worked fine. I'd say don't worry too much.
Old 12-04-2014, 08:47 PM
Winky Dink's Avatar
Thanks.
Winky Dink
Damn the patina,
Full speed ahead!
