Old 08-01-2019, 09:26 AM
VA561's Avatar
VA561 VA561 is offline
Flyback Appearance
I have a Predicta Continental. The set plays well. I noticed that the flyback has a few cracks/splits on the outer covering. No evidence of any wax dripping. Is it best to leave it as is or should it be resealed somehow. I know that sometimes a flyback my look rough but work fine.
File Type: jpg 662BC729-A297-41F6-9E01-516E3953DAB3.jpg (51.4 KB, 46 views)
File Type: jpg E00184C7-EA4F-433A-A227-57E72FB74DBC.jpg (67.7 KB, 35 views)
Old 08-01-2019, 09:38 AM
If there's no arcing/Corona I'd be inclined to leave it be, but if it is or you just don't feel right leaving it go buy a small tube of sensor safe silicone from your local autoparts store, wipe the surface of the fly with a rag dampened with rubbing alcohol to clean the tire, let dry thoroughly, then smoosh some silicone into/over the cracks and let dry...
Old 08-01-2019, 11:24 AM
My Crosley has a cracked flyback and I've never done anything about it and it's never been a issue.
