Old 07-02-2023, 10:00 AM
idan182 idan182 is offline
Which grease for VCR guide tracks?
Hi all
What is the most most suitable grease for the guide tracks?
I have mostly JVC machines which has plastic guide tracks on metal.
and some LG which are only metal parts on metal.
It has to be from amazon since I live overseas.
I have a pentax dielectric grease which is silicone base. can I use it for the tracks?
or
Super Lube 92003 Silicone Lubricating Grease with PTFE
or this cheapest option of FOTU White Lithium Grease for 9$ is ok for most applications?
Thanks
Old 07-02-2023, 12:33 PM
djski djski is offline
I have used a moly grease (MOR 265 ) for the slide tracks and for nylon gears. Lubriplate is an acceptable substitute. You just don't want to use something too thick which I think dielectric grease is.
Old 07-02-2023, 12:54 PM
I've used white lithium before.
Old 07-02-2023, 02:03 PM
Ed in Tx's Avatar
Ed in Tx Ed in Tx is offline
Zenith Walton My 1st TV
This
https://www.amazon.com/Corning-Molyk...ustomerReviews
Old 07-11-2023, 11:38 AM
I've used the white silicon grease that's safe for automotive brakes with good results.
Old 07-14-2023, 05:39 PM
This is what I use. I completely and carefully relubricated my ED Beta EDV-9500 VCR (along with making a replacement gear), and now it works flawlessly again.
