Old 06-12-2024, 11:20 AM
Chris K Chris K is offline
Still Having RCA 8TS30 Issues
Hi all,
Still having problems with this TV. I can't get horizontal lock when I feed a signal into it. I think the best thing to do is list what I've eliminated as possible causes. I am using the 5" CRT for testing and I have left the focus coil in place. It doesn't affect the image focus. All electrolytics and film caps have been replaced along with a couple of 270pf micas in the IF. Here's the list of what I've checked off as probably not causing the issue.
1.Signal Source. I've tried 2 signal generators, a live broadcast feed and I have fed an IF signal into the video IF in 2 places using the B&K 1077. No change in the absence of horizontal lock.
2. Tuner. As I said, I bypassed the tuner by injecting a signal directly into the IF.
3. 5" CRT. Not the cause. Same symptoms on 2 different 10BP4 CRTs.
4. Horizontal and vertical control pots. This is a concentric shaft pair. Each has been cleaned and each ohms out within specification. Just for good measure, I swapped out the control with one from a parts chassis that was cleaned and ohmed. No change in the symptoms.
5. Tubes. Every tube in the TV has been tested, replaced with NOS tubes, swapped out tubes from stock and other working TVs etc. All socket pins cleaned. No change.
6. Control pots on rear of chassis. All extensively cleaned (Horizontal and vertical position, focus, vertical linearity, height, horizontal drive) and tested for resistance. All within specs. Focus, horizontal drive pots swapped out with clean and evaluated pots from parts chassis. No change.
7. Sync Discriminator Transformer T-108. Ohmed and swapped with transformer from parts chassis. No change.
Contrast pot. Cleaned and resistance tested. Replaced with parts chassis pot. Replaced with new 10K pot rigged up separately. No change in symptoms.
So, I'm running out of ideas! I checked the signal from the horizontal oscillator at point A on T-108 and it is clean as a whistle...15.75K and a smooth sine wave. On pin 2 of the Horizontal Sync Discriminator 6AL5, it's a jumping mess of a signal that occasionally looks like an accurate waveform but it scrambles with the picture.
I've been concentrating the troubleshooting in the sync and horizontal circuits and any resistor >10% out of spec has been replaced. I even did some Shango troubleshooting by whacking a few things with the back of a screwdriver with no luck.
I know I've caused some frustration with some being a rookie who doesn't know enough about how these things work and sometimes has taken the experts through pages of messages only to find out the problem isn't in the TV but the signal generator or a bad tube. I apologize for that. I think I'm learning at least to eliminate the dumb stuff first before posting a situation that has me stumped. I'm also getting better at accurately following through with some of the suggestions that are given.
The deflection circuitry on most of these early RCAs is pretty much the same if not identical. My hope is there are some members experienced in these early RCA chassis to provide some insight.
Thanks everyone.
Old 06-12-2024, 12:55 PM
Listed in the SAMS is a rather detailed step by step procedure under horizontal osc adjustment / complete alignment, this sounds like what is needed as a slight retouch most likely won't work, I have not ever had to do this myself, but if it is way off, these steps may help if done as shown.
Also, the RCA service data may have more detailed steps on how to align this area.
Old 06-12-2024, 01:09 PM
Yes I have the service data. I can give the alignment adjustment a try. At least it'll get me to the place where I can narrow down the issue but as persistent as this has been and as many by sight and feel adjustments I've done with the controls, drive and T-108 transformer...all of my improvisational efforts to get this zeroed in have all gotten to the same place...a picture that becomes somewhat locked for a second and is kinda clear and aligned to horizontal chaos.
Old 06-12-2024, 01:29 PM
OK well the first step in a complete realignment is "Tune in a station and adjust the fine tuning for best sound quality. Turn the T-108 frequency adjuster on the rear until the picture is synchronized." I've turned it through its full range slowly and there's no spot where the picture syncs. It gets as close as I've gotten it before, but never full sync.
Old 06-12-2024, 01:39 PM
“a picture that becomes somewhat locked for a second and is kinda clear and aligned to horizontal chaos”.
Under what conditions do/did you observe the “clear” picture?
Old 06-12-2024, 01:59 PM
The only thing I can think of, is out of tol resistors in the sync area, especially near the 6AL5 phase det, when I restored my FADA 630TS clone, many resistors were replaced, if perhaps the 2 470k resistors and the 1m are a bit off, it might upset the horz phasing, I'm sure they were replaced with 1% new in my set, as well as most of the other resistors in the sync area that did not test within 10% what they should have.
Old 06-12-2024, 02:04 PM
The two 470K and 1M resistors have been replaced with 1% resistors. All the resistors around the 6AL5, except for the 5K power resistor that tests spot on, have been replaced
Old 06-12-2024, 02:08 PM
When I fiddle slightly with the horizontal hold or the discriminator frequency or the fine tuning or the brightness pot or the contrast pot or the horizontal drive pot... Let me say when I said clear and stable...I'm talking for less than a second. It seems to change from almost think I can pull it in to awful to worse than awful back to bad almost think I can pull it in etc. I wish I could post a video. It would explain it so much better.
Old 06-12-2024, 02:13 PM
How strong is the vertical lock? Is it just 5 degrees or something more healthy like 1/4 turn.
Sync issues can be caused by 2 things, sync separator issues, and sweep oscillator issues. If vertical lock is weak too it indicates that the sync separator is bad or marginal. And a marginal sync input won't help the horizontal if it too is marginal. Also it's good to consider every component after the H and V sync split part of the osc circuit it feeds and scrutinize those carefully too.
Also the 630 chassis family sets lack AGC so it is possible to have contrast (which in these sets is more accurately called a manual IF and tuner gain control) set so high that the sync pulse gets clipped off at the video detector from signal overload... that's another thing to watch out for that can mess up sync.
Old 06-12-2024, 02:26 PM
Hi Tom...thanks for chiming in! Yes, vertical lock is stable but only compared to the horizontal. It is marginal at best and absolutely loses lock in less than a 1/4 turn. The 3 tubes in the sync circuit are NOS and I've swapped them out with multiple tubes from other TVs and from my stock with no change. I've changed only the resistors that were out of value more than 5% but I still changed 4 resistors. I was just going to change everything in the Sync circuit with 1% resistors. I've been aware of the contrast pot's influence on the signal and I've had it at conservative settings.
Old 06-12-2024, 02:28 PM
Exactly, on mine, I went through each and every resistor end to end, with a parameter of 10%, and any that tested out of that range was replaced, ones that were within got marked with a green ink pen, took me quite a long time to do it.
So you may still be having resistor issues.
Old 06-12-2024, 02:29 PM
One more thing...I don't know if it means anything and I don't know why it is what it is. One of the B+ voltage rails is low...the 135V line is at 95V only. Everything else is bang on. All new bleeder network and 2 brand new 5U4 rectifiers
Old 06-12-2024, 02:51 PM
I would fix the power supply first... could be the main problem.
Old 06-12-2024, 02:53 PM
40 volts too low on that rail, could be an issue, as it does power the sync separator and 2nd sync amp, and other areas.
I had the same sort of problems, but I really doubt it is the same as you are seeing now, but what ever it is, that voltage needs to come up to around where it should be.
Old 06-12-2024, 08:24 PM
I do have additional low voltages. The 275v is 263v. 135v is 101v. -2.0v is -1.7v. -18v is -18.8 and the -100v is -81. What the hell is going on? I'm supposed to have 350v DC on pin 8 of the 5V4 reaction scanning tube and it reads 330v. Supposed to have 300v going into the filter choke and I've got 285v.
