Old 02-16-2025, 09:29 AM
radio nut's Avatar
Born in the wrong decade
Crystal radio question
Hello, i built one of those cheap 80's crystal radio kits. It picks up my 2 local stations decently. I am only using 15 feet of wire. If i add more wire the volume goes down. Why is that? I thought the more antennae the better.
Old 02-16-2025, 10:09 AM
Don't know, maybe it's the stray capacitance of the wire?
How is the wire arranged physically?
Do you have a good ground for the set?
Old 02-16-2025, 10:23 AM
radio nut's Avatar
The ant. wire just goes up and to the left around tools on the peg board and then down towards the floor. For a crystal set does it matter which way the diode points? The instructions aren't clear on that.
Old 02-16-2025, 10:24 AM
radio nut's Avatar
Ground...gies to the breaker box...
Then that goes to ground.
Old 02-16-2025, 05:47 PM
Ground sounds OK.
Not sure what to suggest about the antenna except maybe running it as straight as possible without bending back. When I had a crystal set as a kid in Chicago I threw the antenna wire out the upstairs window and into a tree. It was mostly horizontal and maybe 20 feet long and got a few Chicago stations.
Diode direction should be immaterial, just changes the phase of the audio by 180 degrees.
Old 02-16-2025, 05:50 PM
Just had a thought - how long is the ground wire? Does the ground wire run in the opposite direction from the antenna or more or less the same direction?
Old 02-17-2025, 09:42 AM
radio nut's Avatar
Ground wire 18 inches, and same direction as ant wire
Old 02-17-2025, 11:37 AM
I don't think one that short could be a problem - out of ideas for now.
Old 02-17-2025, 12:25 PM
Dude111 Dude111 is offline
Analogue is Awesome
Hmm maybe adding longer antenna changes how it recieves??
Is the volume lowering OR is the station not being picked up as strong? (That would make voluime seem to go down also)
Old 02-17-2025, 03:04 PM
Did you read the first post? He said using a longer antenna changes reception.
In a crystal set, the volume is entirely dependent on the received signal strength. It's not either/or.
Old 02-17-2025, 03:08 PM
More questions:
When you lengthen the antenna, do you have to retune the station?
What is the tuning mechanism? Variable coil length or variable capacitor?
Can you post a schematic?
Old 02-17-2025, 03:55 PM
radio nut's Avatar
If i lengthen the ant the volume gets weaker and does seem to move on the coil. This is tuned by changing coil length. Could a very cold environment affect the earphone? It is 20 here and this is in my garage.
Old 02-17-2025, 03:59 PM
radio nut's Avatar
I cant get the diagram pic to load correctly
Old 02-17-2025, 04:04 PM
radio nut's Avatar
My camera's pictures are too big file size....wise to load here.
Old 02-17-2025, 06:22 PM
Doubt the temp has much to do with the efficiency unless it affects the diode somehow? Even if it did, it would not account for the difference with antenna length.
You can email me the schematic and I'll post it.
wayne bretl "at" cox "dot" net (no space in name)
