Old 03-27-2025, 02:01 PM
Motorola vt71
Does anyone know when what the indicators are when a 7jp4 crt is getting tired or the phosphor’s are beginning to degrade. I have a bright tube but it’s like having no contrast all white until turning the brightness down some and it’s good I have a new 7jp4 I tried and it don’t do this. so this tube is really bright but don’t know if the emissions are low or phosphors are tired.
Old 03-27-2025, 02:53 PM
While phosphors do degrade slowly over time (burn in), it is minor compared to the cathode degrading, which is what you could be referring to.
Old 03-27-2025, 03:08 PM
So if the cathode, emissions are low or degrading shouldn’t the screen be somewhat darker not super bright ?
Old 03-27-2025, 03:19 PM
depends...
If you lose "cutoff" you lose the ability to have good contrast levels, things start to look washed out, you get the infamous silver faced look when you turn up the brightness.
Old 03-27-2025, 03:27 PM
depends...
Well I have another 7jp4 that is new and the contrast is good on that one.
Old 03-28-2025, 06:17 AM
Slight gassy/soft tube?
Old 03-28-2025, 08:09 AM
Yet another issue the retrace mod was done on this set but I have retrace lines on the bottom of the screen I always seen them on the top and the 220k resistor is good.
Old 03-28-2025, 08:36 AM
On the old tube, or both new and old?
If it's just the older one and not the new, then that is another sign of a tired tube, the elements can no longer react fast enough to the blanking signals any more.
Old 03-28-2025, 09:06 AM
Both tubes the lines are not bad they are faint but can be seen on different scenes
Old 03-28-2025, 10:13 AM
Chris K Chris K is offline
I got very very lucky on my VT-71 acquisition and restoration. It has one of the brightest 7JP4s I've ever seen. I have about 5 others that range in quality from "can't see a thing" to "watchable but not great".
Old 03-28-2025, 10:31 AM
I'm not familiar with the VT-71 or the mod you tried, but most likely there is more than one way to do it, and how well it works most likely depends on the health of the tube, and prob will never get rid of all lines completely, but reduce them to a level where it's much more watchable than it was before added.
