Old 02-15-2003, 06:52 PM
wiseguy wiseguy is offline
Zenith Porthole Question
can anyone tell me about the front covers and picture tube trim on this set if it is suppose to be brass or just a type of clearcoat over the metal.
this set is a "blond"... hard to photograph running and with over head bright 3800K worklights,i was cleaning the front metal parts and what looks like a yellowish clearcoat came off..
this set has been interesting to get running,more so than my ct-100..
thanks!
terry
Old 02-15-2003, 09:06 PM
michael
Guest
Posts: n/a
Porthole clear-coat?
If you have a musical instrument dealer nearby that sells and/or repairs band instruments, they should have one of several brands of gold-toned, clear lacquer you might be able to buy or order. I've used this on the aluminum trim on the front of the Predicta Princess and a GE 800 set with good results, also on brass and steel fan blades. It has just a slight gold tint to it, thus, you can get just about any degree of saturation with successive applications.
Once it 'cures' about 2-3 weeks, it's just about as indestructible as the original coating. Nice looking ZP!
