Old 10-07-2005, 10:22 AM
andrefranc andrefranc is offline
VK Member
Not enough width?
I can't seem to get enough width on this RCA B&W TV, Ch.# KCS38. The width control doesn't do anything and when I removed it completly it still didn't make any difference. The raster lacks about an inch on the right side of filling the screen. What can I do?
Old 10-07-2005, 10:45 AM
Chad Hauris's Avatar
Check for:
bad electrolytics, bad paper caps, weak horizontal output tube, weak damper, weak 5U4 rectifier.
If the set has original capacitors they should all be replaced to get good performance.
Chad Hauris
