Can someone identify this tube?
The markings are washed off this tube, and i wonder what kind it is.
I know the following: It comes from a black and white TV, mid 60s i guess. It has 9 pins (one not connected) and a top connection. It is bigger than most other european tubes. Maybe it is a high voltage rectifyer? Last edited by larschr; 03-13-2009 at 08:53 AM. |
Horizontal output tube?
all the best, mrh |
John Folsom |
Damper diode, possible a PY500 if it was from a european series string set.
Yes, it comes from a European set (maybe a Philips). The heater current is 300mA.
| Audiokarma |
Hi,
I would bet the tube is a PL500 or PL504. Just my 2cents Cheers Giulio Maiocco |
Put the tube in your refridgerator for an hour or two, then remove it and breathe on the glass. The number may become visible in the glass while the condensation remains.
I've had some luck rubbing with a soft leaded pencil, but the fridge trick most always works. Bob |
There were several damper tubes with similar to this in appearence that were used in B&W TVs in the 1960s. I have quite a few of these. The 6V3 has already been mentioned. Others are 20AQ3, 30AQ3, 17BR3, etc. I do not know the origin of the tubes, but they were used in sets sold in the US.
